Saltar al contenido principal
Sony VAIO VPCEE26FX Keyboard Replacement
Qué necesitas
  1. Sony VAIO VPCEE26FX Keyboard Replacement, Battery: paso 1, imagen 1 de 2 Sony VAIO VPCEE26FX Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX Keyboard Replacement: paso 2, imagen 1 de 2 Sony VAIO VPCEE26FX Keyboard Replacement: paso 2, imagen 2 de 2
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX Keyboard Replacement, Keyboard: paso 3, imagen 1 de 2 Sony VAIO VPCEE26FX Keyboard Replacement, Keyboard: paso 3, imagen 2 de 2
    • Flip the laptop back over so it is face up.
    • Open up the laptop.
  4. Sony VAIO VPCEE26FX Keyboard Replacement: paso 4, imagen 1 de 1
    • Using a plastic opening tool, pry along the seam between the keyboard and case to help in separating the two.
    • Continue to lift up gently using the plastic opening tool until the keyboard begins to separate from the case.
  5. Sony VAIO VPCEE26FX Keyboard Replacement: paso 5, imagen 1 de 2 Sony VAIO VPCEE26FX Keyboard Replacement: paso 5, imagen 2 de 2
    • Continue lifting up and moving down starting on the left side of the keyboard moving towards the right side of the computer.
  6. Sony VAIO VPCEE26FX Keyboard Replacement: paso 6, imagen 1 de 2 Sony VAIO VPCEE26FX Keyboard Replacement: paso 6, imagen 2 de 2
    • Carefully tilt the top of the keyboard towards you ensuring the ribbon cable is not under too much tension.
    • Use a pair of tweezers to help remove the plastic adhesive film covering the adapter/port for the ribbon cable.
  7. Sony VAIO VPCEE26FX Keyboard Replacement: paso 7, imagen 1 de 1
  8. Sony VAIO VPCEE26FX Keyboard Replacement: paso 8, imagen 1 de 1
    • Lift the keyboard up and away from the computer.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 1,164
