Saltar al contenido principal
Sony VAIO VPCEE26FX Hard Disk Drive Replacement
Qué necesitas
  1. Sony VAIO VPCEE26FX Hard Disk Drive Replacement, Battery: paso 1, imagen 1 de 2 Sony VAIO VPCEE26FX Hard Disk Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX Hard Disk Drive Replacement: paso 2, imagen 1 de 2 Sony VAIO VPCEE26FX Hard Disk Drive Replacement: paso 2, imagen 2 de 2
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX Hard Disk Drive Replacement, Hard Disk Drive: paso 3, imagen 1 de 2 Sony VAIO VPCEE26FX Hard Disk Drive Replacement, Hard Disk Drive: paso 3, imagen 2 de 2
    • Using a JIS #0 screwdriver, remove the two 4mm screws securing the hard drive cover to the laptop.
    • Lift the hard drive up and out of its place.
    • The drive cover and hard drive are not pictured. They are both missing from this particular device.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 1,734
