Saltar al contenido principal
Sony VAIO VPC-EB33FM Hard Drive Replacement
Qué necesitas
  1. Sony VAIO VPC-EB33FM Hard Drive Replacement, Battery: paso 1, imagen 1 de 2 Sony VAIO VPC-EB33FM Hard Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Power down the laptop by pressing the power button.
    • Turn the laptop onto its backside.
  2. Sony VAIO VPC-EB33FM Hard Drive Replacement: paso 2, imagen 1 de 1
    • To release the battery, hold both the release button and the unlock button at the same time.
  3. Sony VAIO VPC-EB33FM Hard Drive Replacement: paso 3, imagen 1 de 2 Sony VAIO VPC-EB33FM Hard Drive Replacement: paso 3, imagen 2 de 2
    • Remove the battery out from the notch while continuing to hold the release button.
  4. Sony VAIO VPC-EB33FM Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 3 Sony VAIO VPC-EB33FM Hard Drive Replacement, Hard Drive: paso 4, imagen 2 de 3 Sony VAIO VPC-EB33FM Hard Drive Replacement, Hard Drive: paso 4, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove the two 7.8 mm cover screws on the bottom corners of the panel.
  5. Sony VAIO VPC-EB33FM Hard Drive Replacement: paso 5, imagen 1 de 3 Sony VAIO VPC-EB33FM Hard Drive Replacement: paso 5, imagen 2 de 3 Sony VAIO VPC-EB33FM Hard Drive Replacement: paso 5, imagen 3 de 3
    • Use a finger/fingernail to grip the notch at the bottom of the panel to lift it off.
    • You may need to use your other hand to safely remove the panel.
    • You can also use a spudger for this step.
  6. Sony VAIO VPC-EB33FM Hard Drive Replacement: paso 6, imagen 1 de 1
    • Remove the two remaining 7.8 mm screws using the Phillips #00 screwdriver.
  7. Sony VAIO VPC-EB33FM Hard Drive Replacement: paso 7, imagen 1 de 1
    • Grab the tab between your thumb and index finger.
    • Hold the hard drive securely in a horizontal position using your other hand.
    • Push the hard drive to the left using the plastic tab to disconnect it from the laptop.
    • To prevent damage of the connection on the hard disk drive or the laptop, perform this task slowly and with care.
  8. Sony VAIO VPC-EB33FM Hard Drive Replacement: paso 8, imagen 1 de 2 Sony VAIO VPC-EB33FM Hard Drive Replacement: paso 8, imagen 2 de 2
    • While still holding the plastic tab, lift the right side of the hard drive out at a 45º angle.
    • Pull the hard drive out.
  9. Sony VAIO VPC-EB33FM Hard Drive Replacement: paso 9, imagen 1 de 2 Sony VAIO VPC-EB33FM Hard Drive Replacement: paso 9, imagen 2 de 2
    • If you need to remove the bracket from the hard drive, follow the next few steps:
    • Remove the two 3.7 mm screws from either side of the bracket with a Phillips #00 screwdriver.
    • Lift the bracket off the hard drive.
Conclusión
8 personas más completaron esta guía.
Christian
Miembro Desde 01/14/13
177 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 18-39, Regan Winter 2013 Miembro de Cal Poly, Team 18-39, Regan Winter 2013
CPSU-REGAN-W13S18G39
5 Miembros
15 Guías creadas
Un comentario
This is very good step by step instructions guide. Loved it and was able to remove my laptop hd very easily. I created this account only to say thanks to writer. Amazing job !! Thaks ton.
Dinesh - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 21
Todo El Tiempo: 18,439
