Saltar al contenido principal
Sony VAIO VGN-FW 590 Keyboard Key Replacement
Qué necesitas
  1. Sony VAIO VGN-FW 590 Keyboard Key Replacement, Keyboard Key: paso 1, imagen 1 de 1
    • Open your computer.
    • Make sure the computer is turned off.
  2. Sony VAIO VGN-FW 590 Keyboard Key Replacement: paso 2, imagen 1 de 1
    • Find the broken key.
    • The S key is our example though it is not broken.
  3. Sony VAIO VGN-FW 590 Keyboard Key Replacement: paso 3, imagen 1 de 2 Sony VAIO VGN-FW 590 Keyboard Key Replacement: paso 3, imagen 2 de 2
    • Insert the plastic spudger underneath the edge of the key.
    • Lift the key until it pops off on all four corners. There should be a white plastic base underneath the key.
  4. Sony VAIO VGN-FW 590 Keyboard Key Replacement: paso 4, imagen 1 de 1
    • Orient replacement key over the white plastic base, so it is aligned properly with the other keys.
    • Press the replacement key firmly in the center until it is completely depressed and attached to the key base.
  5. Sony VAIO VGN-FW 590 Keyboard Key Replacement: paso 5, imagen 1 de 1
    • Test the key by releasing the key. It should pop up and look like the rest of the keys on the keyboard.
Conclusión
Congratulations! You have successfully replaced a key on your keyboard.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 1,495
