Saltar al contenido principal
Sony VAIO VGN-FW 590 Battery Replacement
Qué necesitas
  1. Sony VAIO VGN-FW 590 Battery Replacement, Battery: paso 1, imagen 1 de 2 Sony VAIO VGN-FW 590 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the computer off, close the LCD screen, and insure the computer is unplugged from any outlet.
    • Turn the computer over so that the bottom of the computer is facing up and the "screen swivels" (DC in port and On button) are facing away from you.
    • Locate the battery pack between the two "screen swivels" at the top of the computer back.
  2. Sony VAIO VGN-FW 590 Battery Replacement: paso 2, imagen 1 de 2 Sony VAIO VGN-FW 590 Battery Replacement: paso 2, imagen 2 de 2
    • Locate two sliding release switches below the battery pack.
    • Slide the "Lock" release to the right toward the center of the computer.
    • Slide the "Release" switch to the left, toward the center of the computer. It must be held in place because it is spring loaded.
  3. Sony VAIO VGN-FW 590 Battery Replacement: paso 3, imagen 1 de 2 Sony VAIO VGN-FW 590 Battery Replacement: paso 3, imagen 2 de 2
    • While holding the "Release" switch toward the center of the computer, press on the raised portion of the battery pack away from you. The battery pack will pop up.
    • Once the battery pack has popped out of its compartment, lift it out of the computer.
Conclusión
Morton Wakeland
Miembro Desde 10/30/17
101 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 19
Todo El Tiempo: 812
