Saltar al contenido principal
Sony VAIO SVE14AJ16L Wireless Network Card Replacement
Qué necesitas
  1. Sony VAIO SVE14AJ16L Wireless Network Card Replacement, Wireless Network Card: paso 1, imagen 1 de 1
    • Remove the twelve 5 mm Phillips #0 screws from the bottom of the laptop.
  2. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: paso 2, imagen 1 de 1
    • Remove the two 5 mm Phillips #0 screws from the bottom of the laptop.
  3. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: paso 3, imagen 1 de 1
    • Using the plastic prying tools, go around the edge of the bottom of the laptop to release the cover.
  4. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: paso 4, imagen 1 de 1
    • Disconnect the black and white antenna wires from the wifi card.
    • Make sure to lift the plugs straight up from the sockets and not from an angle.
  5. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: paso 5, imagen 1 de 2 Sony VAIO SVE14AJ16L Wireless Network Card Replacement: paso 5, imagen 2 de 2
    • Remove the 3 mm Phillips #0 screw from the wifi card.
    • Remove the card from its socket.
Conclusión
2 personas más completaron esta guía.
2 comentarios
Perfect hardware guide, but i make this and windows 10 recognizes the card, but does not start the Wifi, my laptop SVE14A2X1EW does not have wifi switch or Fn buttons, and I have no way to enable the wifi, some trick?
VirusBCN - Contestar
Please follow this guide to enable wifi and bluetooth on this device for any modern wifi card:
gsid.in/using-old-mini-pcie-wlan-cards-in-modern-laptops/
Daniel - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 13
Ultimos 30 días: 26
Todo El Tiempo: 2,440
