Introducción
Does your laptop have a non-functioning battery or just want a replacement? This guide shows how to replace the battery in the Sony VAIO SVE14A26CGH.
To begin with, you must first turn the laptop upside down and locate the battery.
Locate the 'Lock' tab and slide the slider away from the word 'Lock', or slide it up.
Slide up the release tab, and put your fingers into the small gap.
Pull up the battery while holding the release tab up, then remove the battery.
