Saltar al contenido principal
Sony VAIO PCG-F360 Single Key Replacement
Qué necesitas
  1. Sony VAIO PCG-F360 Single Key Replacement, Battery: paso 1, imagen 1 de 1
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony VAIO PCG-F360 Single Key Replacement: paso 2, imagen 1 de 1
    • Lift the panel up and then out to gain access to the battery.
  3. Sony VAIO PCG-F360 Single Key Replacement: paso 3, imagen 1 de 1
    • Use the indentations to pull the old battery out.
  4. Sony VAIO PCG-F360 Single Key Replacement: paso 4, imagen 1 de 1
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. Sony VAIO PCG-F360 Single Key Replacement, Single Key: paso 5, imagen 1 de 3 Sony VAIO PCG-F360 Single Key Replacement, Single Key: paso 5, imagen 2 de 3 Sony VAIO PCG-F360 Single Key Replacement, Single Key: paso 5, imagen 3 de 3
    • Use the pludger to pop off the key by prying under it.
    • You now can clean and replace the key.
Conclusión
Hannah Millea
Miembro Desde 03/11/14
401 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 209
