Saltar al contenido principal
Sony VAIO PCG-933A Keyboard Replacement
Qué necesitas
  1. Sony VAIO PCG-933A Keyboard Replacement, Battery: paso 1, imagen 1 de 2 Sony VAIO PCG-933A Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the laptop upside down so that the top is sitting on a flat surface.
    • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  2. Sony VAIO PCG-933A Keyboard Replacement: paso 2, imagen 1 de 3 Sony VAIO PCG-933A Keyboard Replacement: paso 2, imagen 2 de 3 Sony VAIO PCG-933A Keyboard Replacement: paso 2, imagen 3 de 3
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
  3. Sony VAIO PCG-933A Keyboard Replacement, Keyboard: paso 3, imagen 1 de 1
    • Remove the four 16 mm screws bordering the edge of the laptop using a Phillips #0 screwdriver.
  4. Sony VAIO PCG-933A Keyboard Replacement: paso 4, imagen 1 de 2 Sony VAIO PCG-933A Keyboard Replacement: paso 4, imagen 2 de 2
    • Remove the 4mm screw on the right rear side of the laptop next to the audio ports using a Phillips #0 screwdriver.
    • This will release the speaker grille.
  5. Sony VAIO PCG-933A Keyboard Replacement: paso 5, imagen 1 de 1
    • Flip the computer so the key board is facing up.
  6. Sony VAIO PCG-933A Keyboard Replacement: paso 6, imagen 1 de 3 Sony VAIO PCG-933A Keyboard Replacement: paso 6, imagen 2 de 3 Sony VAIO PCG-933A Keyboard Replacement: paso 6, imagen 3 de 3
    • Slide the blue speaker grille (located above the keyboard) to the right and gently pull upward. The grille will still be connected by a white electrical strip.
    • Carefully pull out the white electrical strip. By doing this you will remove the speaker grille.
  7. Sony VAIO PCG-933A Keyboard Replacement: paso 7, imagen 1 de 3 Sony VAIO PCG-933A Keyboard Replacement: paso 7, imagen 2 de 3 Sony VAIO PCG-933A Keyboard Replacement: paso 7, imagen 3 de 3
    • Remove the 4mm screw in the center using a Phillips screwdriver.
    • Carefully and slowly pull the green strip straight up (away from the laptop) to disconnect it. Make sure not to pull too hard to avoid breaking.
    • The keyboard can now be removed.
Conclusión
Sara Lillard
Miembro Desde 04/11/11
165 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 12-36, Maness Spring 2011 Miembro de Cal Poly, Team 12-36, Maness Spring 2011
CPSU-MANESS-S11S12G36
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 1,785
