Introducción
This repair guide shows how to replace and clean out the fan.
Herramientas
Partes
No se especificaron partes.
Turn the laptop upside down
The battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
Remove the four 16mm Phillips screws bordering the edge of the laptop, indicated here.
Remove the four 4mm Phillips screws around the hard drive.
Carefully lift the hard drive cage out.
Carefully disconnect the copper strip to pull out the hard drive.
Una persona más ha completado esta guía.
