Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This guide is to replace a dead or damaged battery in the laptop.
  1. Turn the laptop upside down The battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
    • Turn the laptop upside down
    • The battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  2. As shown by the arrow, slide the plastic cover up and then pull out and downwards. You should now be able to pull the battery out. You should now be able to pull the battery out.
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
Conclusión
Sara Lillard
Miembro Desde 11/04/11
165 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 12-36, Maness Spring 2011 Miembro de Cal Poly, Team 12-36, Maness Spring 2011
CPSU-MANESS-S11S12G36
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,415
