Saltar al contenido principal
Sony VAIO VPCEC1M1E Keyboard Replacement
Qué necesitas
  1. Sony VAIO VPCEC1M1E Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Remove the following color-coded screws:
    • These screws secure the RAM and hard drive covers, respectively.
    • These screws secure the optical drive to the lower case of the laptop.
    • The various other screws highlighted in the picture are unnecessary to remove and should be done at your own discretion.
  2. Sony VAIO VPCEC1M1E Keyboard Replacement: paso 2, imagen 1 de 1
    • Remove the following screws:
    • Five screws highlighted in orange.
    • Two screws highlighted in blue.
    • Pry the hard drive connector upwards from its socket on the logic board.
  3. Sony VAIO VPCEC1M1E Keyboard Replacement: paso 3, imagen 1 de 1
    • Release the highlighted clips to remove the upper case of the keyboard.
  4. Sony VAIO VPCEC1M1E Keyboard Replacement: paso 4, imagen 1 de 3 Sony VAIO VPCEC1M1E Keyboard Replacement: paso 4, imagen 2 de 3 Sony VAIO VPCEC1M1E Keyboard Replacement: paso 4, imagen 3 de 3
    • Flip up the retaining flap (highlighted in red) on the keyboard ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap and not the socket itself.
    • Pull the keyboard ribbon cable straight out of its socket toward the front edge of the laptop.
Linea de Meta
7 personas más completaron esta guía.
Stephan
Miembro Desde 08/20/11
199 Reputación
1 Guía escrita
3 comentarios
Very useful, thank you. A real pain to do though without snapping the plastic tabs on the upper case.
Eddie B - Contestar
OMG... guys, you need just unscrew FOUR screws on the bottom (two orange circles on the same level that yellow sticker and two orange-circled screws in the middle of left and right side) and then pop the keyboard up with knife, etc, and disconnect the cable.
Paul G - Contestar
agree with Paul G. you don’t need to remove all the plastic case to change the keyboard
Pierret -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 22
Todo El Tiempo: 23,002
