Saltar al contenido principal
Sony UBP-UX80 Power Board Replacement
Qué necesitas
  1. Sony UBP-UX80 Power Board Replacement, Top Cover: paso 1, imagen 1 de 3 Sony UBP-UX80 Power Board Replacement, Top Cover: paso 1, imagen 2 de 3 Sony UBP-UX80 Power Board Replacement, Top Cover: paso 1, imagen 3 de 3
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws that secure the two side panels onto the back of the player.
    • Slide both covers back about a 1/2 inch, then pull them away from the case.
  2. Sony UBP-UX80 Power Board Replacement: paso 2, imagen 1 de 3 Sony UBP-UX80 Power Board Replacement: paso 2, imagen 2 de 3 Sony UBP-UX80 Power Board Replacement: paso 2, imagen 3 de 3
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws on the side of the case, each connecting to a tab on the cover.
    • Similar to the previous step, it is identical cases on both sides of the device.
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws (one next to the Wi-Fi logo and one next to the Blu-ray logo).
  3. Sony UBP-UX80 Power Board Replacement: paso 3, imagen 1 de 2 Sony UBP-UX80 Power Board Replacement: paso 3, imagen 2 de 2
    • Press in the tabs found on the front-sides of the case (connected to the front panel).
    • Slide the top cover forward.
    • Lift off the case.
  4. Sony UBP-UX80 Power Board Replacement: paso 4, imagen 1 de 3 Sony UBP-UX80 Power Board Replacement: paso 4, imagen 2 de 3 Sony UBP-UX80 Power Board Replacement: paso 4, imagen 3 de 3
    • Find the eleven 10.5 mm silver screws and two 6 mm black screws on the perimeter of the silver cover plate.
    • Remove the silver screws using a Phillips #2 screwdriver and the black ones using a Phillips #1 screwdriver.
    • Life the back of the cover up and off of the chasis.
  5. Sony UBP-UX80 Power Board Replacement, Power Board: paso 5, imagen 1 de 2 Sony UBP-UX80 Power Board Replacement, Power Board: paso 5, imagen 2 de 2
    • Unplug device before starting. Try not to touch any exposed wires or traces on the board.
    • Disconnect the power cable connector and motherboard connector from the power board.
  6. Sony UBP-UX80 Power Board Replacement: paso 6, imagen 1 de 3 Sony UBP-UX80 Power Board Replacement: paso 6, imagen 2 de 3 Sony UBP-UX80 Power Board Replacement: paso 6, imagen 3 de 3
    • Use a Phillips #2 screwdriver to remove the six 10.5 mm screws that secure the board.
    • Note that there are two (2) screws with washers attached to them at the top of the board, please know where they go.
  7. Sony UBP-UX80 Power Board Replacement: paso 7, imagen 1 de 1
    • Grab the board by any plastic housing attached. Lift the board up and out of the chassis.
Conclusión
Ryan Masoud
Miembro Desde 03/13/23
193 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 109
