Introducción
Your disc drive begins to start malfunctioning, clicks or makes weird sound when you go to eject, or fails to read the disc [knowing you are using a good disc].
Qué necesitas
Use a Phillips #2 screwdriver to remove the two 10.5 mm screws that secure the two side panels onto the back of the player.
Slide both covers back about a 1/2 inch, then pull them away from the case.
Find and remove the three ribbon connections leading to the motherboard.
Gently pull straight up. Be careful because ribbon cables are fragile.
