Saltar al contenido principal
Sony Tablet S Rear Camera Replacement
Qué necesitas
  1. Sony Tablet S Rear Camera Replacement, Rear Camera: paso 1, imagen 1 de 2 Sony Tablet S Rear Camera Replacement, Rear Camera: paso 1, imagen 2 de 2
    • Ensure that the device is completely turned off before attempting a repair. The battery may still have charge; use caution touching the components.
    • Use a plastic opening tool to remove the two rubber grips on the back of the tablet.
  2. Sony Tablet S Rear Camera Replacement: paso 2, imagen 1 de 1
    • Remove the two 10mm Phillips #0 screws located under the grips.
  3. Sony Tablet S Rear Camera Replacement: paso 3, imagen 1 de 2 Sony Tablet S Rear Camera Replacement: paso 3, imagen 2 de 2
    • Flip the tablet over and use a plastic opening tool to pry the casing away from the top of the screen. Push the back cover off.
    • There is adhesive holding the case on located at the top of the screen. Push the casing toward the top of the screen while also wiggling it back and forth.
  4. Sony Tablet S Rear Camera Replacement: paso 4, imagen 1 de 1
    • Remove the copper ribbon cable by gently using a spudger to pry it up from its socket.
    • Use caution when removing the cable, as the socket is very fragile.
  5. Sony Tablet S Rear Camera Replacement: paso 5, imagen 1 de 2 Sony Tablet S Rear Camera Replacement: paso 5, imagen 2 de 2
    • Use a finger or a spudger to pull on camera housing.
  6. Sony Tablet S Rear Camera Replacement: paso 6, imagen 1 de 1
    • Remove the assembly from the plastic shielding.
Conclusión
Austin Mann
Miembro Desde 09/28/16
287 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 3-5, Passmore Fall 2016 Miembro de USF Tampa, Team 3-5, Passmore Fall 2016
USFT-PASSMORE-F16S3G5
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 367
