Saltar al contenido principal
Sony Tablet S Front Camera Replacement
Qué necesitas
  1. Sony Tablet S Front Camera Replacement, Battery: paso 1, imagen 1 de 2 Sony Tablet S Front Camera Replacement, Battery: paso 1, imagen 2 de 2
    • Ensure that the device is completely turned off before attempting a repair. The battery may still have charge; use caution touching the components.
    • Use a plastic opening tool to remove the two rubber grips on the back of the tablet.
  2. Sony Tablet S Front Camera Replacement: paso 2, imagen 1 de 1
    • Remove the two 10mm Phillips #0 screws located under the grips.
  3. Sony Tablet S Front Camera Replacement: paso 3, imagen 1 de 2 Sony Tablet S Front Camera Replacement: paso 3, imagen 2 de 2
    • Flip the tablet over and use a plastic opening tool to pry the casing away from the top of the screen. Push the back cover off.
    • There is adhesive holding the case on located at the top of the screen. Push the casing toward the top of the screen while also wiggling it back and forth.
  4. Sony Tablet S Front Camera Replacement: paso 4, imagen 1 de 1
    • Once the casing is off, remove the nine 5mm Phillips #0 screws shown.
  5. Sony Tablet S Front Camera Replacement: paso 5, imagen 1 de 1
    • Remove the white ribbon cable by pulling the blue tab straight up out of the socket and then peeling up the tape securing it to the tablet.
    • Use caution when removing the cable, as the socket is very fragile.
  6. Sony Tablet S Front Camera Replacement: paso 6, imagen 1 de 1
    • Remove the copper ribbon cable by gently using a spudger to pry it up from its socket.
  7. Sony Tablet S Front Camera Replacement: paso 7, imagen 1 de 1
    • Slide the bottom grey cover piece away from the body and remove it.
    • If this piece gives resistance, use a spudger on the sides of the tablet to pry it loose.
  8. Sony Tablet S Front Camera Replacement: paso 8, imagen 1 de 1
    • Remove the five 4mm Phillips #000 screws.
    • Remove the two 5mm Phillips #000 screws holding the charger in place.
  9. Sony Tablet S Front Camera Replacement: paso 9, imagen 1 de 3 Sony Tablet S Front Camera Replacement: paso 9, imagen 2 de 3 Sony Tablet S Front Camera Replacement: paso 9, imagen 3 de 3
    • Position the charging port at an angle so you can thread it through the opening as you remove the black plastic cover from the back of the tablet.
    • If the cover is not coming off easily, use a plastic opening tool to pry it loose from the edges of the screen.
  10. Sony Tablet S Front Camera Replacement: paso 10, imagen 1 de 2 Sony Tablet S Front Camera Replacement: paso 10, imagen 2 de 2
    • Use a spudger to lift the zero insertion force connector latch for the long ribbon cable to the right of the battery, then pull the cable loose from its socket.
  11. Sony Tablet S Front Camera Replacement: paso 11, imagen 1 de 1
    • Remove the three 5mm Phillips #0 screws securing the original battery.
  12. Sony Tablet S Front Camera Replacement: paso 12, imagen 1 de 2 Sony Tablet S Front Camera Replacement: paso 12, imagen 2 de 2
    • Use the spudger to pop the battery loose and remove the battery.
  13. Sony Tablet S Front Camera Replacement, Front Camera: paso 13, imagen 1 de 1
    • Remove the single 5mm #0 Philips screw.
  14. Sony Tablet S Front Camera Replacement: paso 14, imagen 1 de 1
    • Remove the camera assembly.
Conclusión
Austin Mann
Miembro Desde 09/28/16
287 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 3-5, Passmore Fall 2016 Miembro de USF Tampa, Team 3-5, Passmore Fall 2016
USFT-PASSMORE-F16S3G5
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 496
