Saltar al contenido principal
Sony TCM-919 Cassette-Corder Speaker Replacement
Qué necesitas
  1. Sony TCM-919 Cassette-Corder Speaker Replacement, Remove Battery Cover: paso 1, imagen 1 de 1
    • Turn the device around so that the back cover is facing upward. Use your thumbs to press firmly down and then push the battery door cover open.
    • Remove any batteries.
  2. Sony TCM-919 Cassette-Corder Speaker Replacement, Remove Back Casing: paso 2, imagen 1 de 1
    • Remove the 5, 5.95mm screws as indicated in the picture.
  3. Sony TCM-919 Cassette-Corder Speaker Replacement, Desolder Speaker Wires: paso 3, imagen 1 de 2 Sony TCM-919 Cassette-Corder Speaker Replacement, Desolder Speaker Wires: paso 3, imagen 2 de 2
    • Look to the back of the top cover.
    • Desolder the two wires from the speaker.
  4. Sony TCM-919 Cassette-Corder Speaker Replacement, Remove Speaker: paso 4, imagen 1 de 2 Sony TCM-919 Cassette-Corder Speaker Replacement, Remove Speaker: paso 4, imagen 2 de 2
    • Squeeze the two prongs holding the speaker in place and remove the metal piece.
    • Remove the speaker by gently lifting it up from the cover and pulling.
Conclusión
Equipo
Baylor, Team 4-3, Williams Fall 2014 Miembro de Baylor, Team 4-3, Williams Fall 2014
BU-WILLIAMS-F14S4G3
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 510
