Saltar al contenido principal
Sony TCM-919 Cassette-Corder Operating Buttons Replacement
Qué necesitas
  1. Sony TCM-919 Cassette-Corder Operating Buttons Replacement, Remove Back Cover: paso 1, imagen 1 de 1
    • Turn the device around so that the back cover if facing upward. Use your thumbs to press firmly down and then push the battery door cover open.
    • Remove any batteries.
  2. Sony TCM-919 Cassette-Corder Operating Buttons Replacement, Back Cover Screw Removal: paso 2, imagen 1 de 1
    • Remove the 5 5.95mm screws as indicated in the picture with the Phillips Head screwdriver.
  3. Sony TCM-919 Cassette-Corder Operating Buttons Replacement, Locate Buttons: paso 3, imagen 1 de 1
    • Look to the back of the top cover and locate the broken button(s).
  4. Sony TCM-919 Cassette-Corder Operating Buttons Replacement, Detach Buttons: paso 4, imagen 1 de 2 Sony TCM-919 Cassette-Corder Operating Buttons Replacement, Detach Buttons: paso 4, imagen 2 de 2
    • Use a splunger tool to undo the two clips that belong to any broken buttons.
    • Turn the device over and using your finger, push out the loose button.
Conclusión
Equipo
Baylor, Team 4-3, Williams Fall 2014 Miembro de Baylor, Team 4-3, Williams Fall 2014
BU-WILLIAMS-F14S4G3
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 828
