Saltar al contenido principal
Sony TCM-919 Cassette-Corder Microphone Replacement
Qué necesitas
  1. Sony TCM-919 Cassette-Corder Microphone Replacement, Remove battery Cover: paso 1, imagen 1 de 1
    • Turn the device around so that the back cover if facing upward. Use your thumbs to press down firmly and then push the battery door cover open.
    • Remove any batteries.
  2. Sony TCM-919 Cassette-Corder Microphone Replacement, Remove Back Casing: paso 2, imagen 1 de 1
    • Remove the 5, 5.95mm screws as indicated in the picture using the Phillips head screwdriver.
  3. Sony TCM-919 Cassette-Corder Microphone Replacement, Desolder Microphone Wires: paso 3, imagen 1 de 2 Sony TCM-919 Cassette-Corder Microphone Replacement, Desolder Microphone Wires: paso 3, imagen 2 de 2
    • Look to the back of the top cover.
    • Desolder the two wires connected to the mircophone using the soldering station.
  4. Sony TCM-919 Cassette-Corder Microphone Replacement, Remove Microphone: paso 4, imagen 1 de 2 Sony TCM-919 Cassette-Corder Microphone Replacement, Remove Microphone: paso 4, imagen 2 de 2
    • Gently remove the rubber top from the two plastic knobs that hold the microphone in place.
    • Remove the microphone by pulling up.
Conclusión
Equipo
Baylor, Team 4-3, Williams Fall 2014 Miembro de Baylor, Team 4-3, Williams Fall 2014
BU-WILLIAMS-F14S4G3
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 518
