Saltar al contenido principal
Sony Smart Watch SW2 Display Assembly Replacement
Qué necesitas
  1. Sony Smart Watch SW2 Display Assembly Replacement, Display Assembly: paso 1, imagen 1 de 1
    • Detach the smart watch from the band by pushing on the back of the watch housing.
    • The power button may fall out once the smart watch is detached.
    • Set aside the power button and watch band as they are no longer needed for further disassembly.
  2. Sony Smart Watch SW2 Display Assembly Replacement: paso 2, imagen 1 de 1
    • Use a plastic opening tool to carefully pry the LCD screen from the watch housing.
  3. Sony Smart Watch SW2 Display Assembly Replacement: paso 3, imagen 1 de 1
    • Use a plastic opening tool or spudger to lift the screen assembly press-fit connector free.
  4. Sony Smart Watch SW2 Display Assembly Replacement: paso 4, imagen 1 de 1
    • Set aside the detached LCD screen to access the battery.
Conclusión
To reassemble your device, follow these steps in reverse order.
2 personas más completaron esta guía.
Vincent Shiue
Miembro Desde 01/22/18
256 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G5, Freund Spring 2018 Miembro de IUPUI, Team S1-G5, Freund Spring 2018
IUPUI-FREUND-S18S1G5
3 Miembros
2 Guías creadas
Un comentario
whwre can I get the LCD screen for SW2?
faizal ahamed - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 29
Todo El Tiempo: 2,941
