Saltar al contenido principal
Sony SS-CCP1 Speaker Replacement
Qué necesitas
  1. Sony SS-CCP1 Speaker Replacement, Screen: paso 1, imagen 1 de 3 Sony SS-CCP1 Speaker Replacement, Screen: paso 1, imagen 2 de 3 Sony SS-CCP1 Speaker Replacement, Screen: paso 1, imagen 3 de 3
    • Pull screen cover from the edges for removal. This will not require much effort.
  2. Sony SS-CCP1 Speaker Replacement, Speaker: paso 2, imagen 1 de 2 Sony SS-CCP1 Speaker Replacement, Speaker: paso 2, imagen 2 de 2
    • Remove the seven 18.06mm PH1 screws.
  3. Sony SS-CCP1 Speaker Replacement: paso 3, imagen 1 de 3 Sony SS-CCP1 Speaker Replacement: paso 3, imagen 2 de 3 Sony SS-CCP1 Speaker Replacement: paso 3, imagen 3 de 3
    • Remove the crimps from the tweeter speaker.
    • If its not connected too tightly the crimps can be removed by hand pressure only.
    • If its too tight to be removed by hand, then you can use a pair of pliers to removed the crimps.
    • Never remove by pulling on the cables. Always pull by the metal crimps.
  4. Sony SS-CCP1 Speaker Replacement: paso 4, imagen 1 de 3 Sony SS-CCP1 Speaker Replacement: paso 4, imagen 2 de 3 Sony SS-CCP1 Speaker Replacement: paso 4, imagen 3 de 3
    • Remove the crimps from the 12cm loudspeaker.
  5. Sony SS-CCP1 Speaker Replacement: paso 5, imagen 1 de 2 Sony SS-CCP1 Speaker Replacement: paso 5, imagen 2 de 2
    • Remove the grommet using an object with a flat edge.
    • The grommet is not made of rubber, it is made of plastic. Be careful when removing it, as it can break easily.
  6. Sony SS-CCP1 Speaker Replacement: paso 6, imagen 1 de 2 Sony SS-CCP1 Speaker Replacement: paso 6, imagen 2 de 2
    • Feed the speaker cable through the front of the box.
Conclusión
4 personas más completaron esta guía.
Dallas
Miembro Desde 10/10/16
892 Reputación
3 Guías creadas
Equipo
IUPUI, Team 3-2, Baechle Fall 2016 Miembro de IUPUI, Team 3-2, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G2
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 33
Todo El Tiempo: 3,914
