Introducción
In this guide, you will be removing and replacing a faulty LED control panel located on the back of the speaker plate. If your LED lights aren't working on your SONY SRS-XB40 speaker, then more than likely the control panel is at fault.
Qué necesitas
Remove the speaker case from the outer casing by prying it from the base of the speaker using a metal spudger.
After you take the speaker plate off the body of the speaker, locate the LED control panels on each end of the speaker plate.
