Introducción
Este sistema de audio es el modelo SRS-XB30. Entre las averías más comunes de este sistema de audio se incluyen el fallo de los altavoces, la incapacidad de carga y el problema de emparejamiento Bluetooth.
Qué necesitas
Para quitar la rejilla del altavoz, inserta el spudger grande debajo de él en cada esquina.
Para volver a montar el dispositivo, sigue estas instrucciones en orden inverso.
24 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
¡ Carlos López (España - Spain) nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
8 comentarios
Hello. Would you upload a detailed photo of the motherboard and the built-in amplifier? I’d like to know if I could find the right IC which I want to change. Thank you! and great guide!
Can you help with what kind of battery I need? I would like to purchase it before I take everything apart. Thank you.
Here you can see the answer. https://www.amazon.com/Replacement-SRS-X...
I really like the sound of this BT device. That´s why I own one of these. I just want to know how to convert this rechargeable speaker into AC power supply device because I don´t want to buy a battery replacement when the original one runs out. I don´t know how to calculate the volts and amperes needed to supply this speaker.
Which adhesive should be bought to put it all back together? Are there parts which can break or go in unoriginal form and should be romoved or fixed back together carefully? Also the link for the battery on amazon which is posted cant supply right now: is there any alternatives?
Thank you for making this guide and helping out :D
