Introducción
The power unit is obviously what powers your device. Without this you cannot use the device at all whatsoever.
Use this guide to uninstall the power unit from your device, then follow it in reverse order to install the new part.
Qué necesitas
On the bottom of the device, you'll see 4 rubber pieces at the corners. Peel off these rubber pieces.
Unscrew the 4 10mm Philips J1 screws beneath them.
3 personas más completaron esta guía.
4 comentarios
Hi, do you know where can I find the replacement battery doy te SRS X7. THANKS
Hi I replaced my old battery with a new one (LIS2128HNPD). At amazon they say it is a replacement for the SRS-X5 but it perfectly fits in the X7 model too. Unfortunately the battery seems not to be charged (no orange led and the power supply has no load). Can anybody help?
Hi, did you fixed it? I wonder if it’s really the same battery or if you got defect electronics. :-)
yo ! -
I am having the same problem . I wonder if the charging board that is wrapped in with the battery will have to be swapped from original battery to new battery?
