Saltar al contenido principal
Sony SRS-X55 Speaker Reverberator Replacement
Qué necesitas
  1. Sony SRS-X55 Speaker Reverberator Replacement, Speaker Reverberator: paso 1, imagen 1 de 1
    • Locate the six 9 mm screws on the bottom of the speaker and remove them using Phillips head #2.
  2. Sony SRS-X55 Speaker Reverberator Replacement: paso 2, imagen 1 de 2 Sony SRS-X55 Speaker Reverberator Replacement: paso 2, imagen 2 de 2
    • Insert a plastic spudger into the seam on the bottom panel and lift it away from the rest of the speaker.
  3. Sony SRS-X55 Speaker Reverberator Replacement: paso 3, imagen 1 de 3 Sony SRS-X55 Speaker Reverberator Replacement: paso 3, imagen 2 de 3 Sony SRS-X55 Speaker Reverberator Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Locate the battery connection and unplug it using a pair of metal tweezers.
  4. Sony SRS-X55 Speaker Reverberator Replacement: paso 4, imagen 1 de 2 Sony SRS-X55 Speaker Reverberator Replacement: paso 4, imagen 2 de 2
    • Locate the remaining two 3.5 mm screws on the bottom of the I/O board and remove them using a Phillips head #2 screwdriver.
  5. Sony SRS-X55 Speaker Reverberator Replacement: paso 5, imagen 1 de 1
    • Remove the I/O board from the rest of the speaker. A plastic spudger can aid in this process if it is inserted into the edge as shown and gently pried.
  6. Sony SRS-X55 Speaker Reverberator Replacement: paso 6, imagen 1 de 2 Sony SRS-X55 Speaker Reverberator Replacement: paso 6, imagen 2 de 2
    • Insert a plastic spudger into the seam where the forward facing metal speaker cover meets the speaker body and gently pry it upward until it releases.
  7. Sony SRS-X55 Speaker Reverberator Replacement: paso 7, imagen 1 de 2 Sony SRS-X55 Speaker Reverberator Replacement: paso 7, imagen 2 de 2
    • Locate the eight 8.9 mm screws on the face of the speaker assembly and remove them using a Phillips head #2 screwdriver.
  8. Sony SRS-X55 Speaker Reverberator Replacement: paso 8, imagen 1 de 2 Sony SRS-X55 Speaker Reverberator Replacement: paso 8, imagen 2 de 2
    • Insert a plastic spudger underneath one of the tabs on the front of the speaker assembly and gently raise it.
    • Continue to the next step before attempting to lift the speaker assembly entirely away from the rest of the speaker to avoid damaging internal wire connections.
  9. Sony SRS-X55 Speaker Reverberator Replacement: paso 9, imagen 1 de 3 Sony SRS-X55 Speaker Reverberator Replacement: paso 9, imagen 2 de 3 Sony SRS-X55 Speaker Reverberator Replacement: paso 9, imagen 3 de 3
    • Locate the two wire connections as shown underneath of the speaker assembly and unplug them using a pair of tweezers.
    • Lift the speaker assembly away.
  10. Sony SRS-X55 Speaker Reverberator Replacement: paso 10, imagen 1 de 2 Sony SRS-X55 Speaker Reverberator Replacement: paso 10, imagen 2 de 2
    • Locate the eight 7.5 mm screws across both of the speaker reverberators and remove them using a Phillips head #2 screwdriver.
    • Lift the speaker reverberators away and replace them.
Conclusión
2 personas más completaron esta guía.
Eric Coletto
Miembro Desde 01/26/17
113 Reputación
1 Guía escrita
Equipo
IUPUI, Team 2-3, Baechle Spring 2017 Miembro de IUPUI, Team 2-3, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G3
3 Miembros
3 Guías creadas
Un comentario
Nice Guide, but do you know the exact speaker size and/or type?
I can not find the exact speakers.
THX
Elduderino79
El Duderino - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 1,527
