Introducción
If the controls or indicator LEDs of your Sony SRS-X55 have stopped working, use this guide to replace the speaker's button board.
Qué necesitas
Remove the six screw covers with a spudger.
Remove the six 11 mm Phillips screws from the bottom panel.
Remove the bottom panel of the speaker.
Using the flat side of the metal spudger, apply pressure to underside of the cover to loosen the adhesive and separate the cover from the top of the speaker.
3 personas más completaron esta guía.
4 comentarios
My touch system has got stuck in audio in and sound mode when i press the switch on button it powers on. But ater that Although I press on the bluetooth pairing button it does not come on and i can use the set only in wired mode from tab to speaker also i cant manually switch off either.I have to let it idle to allow it to switch on on its own. The lights are on but touch is not responding its stuck in audio in and sound mode. Please advice what should I do please. I cant use the speaker in blue tooth mode. Regards ranil
