Saltar al contenido principal
Sony SRS-X5 USB/AUX plug in Replacement
Qué necesitas
  1. Sony SRS-X5 USB/AUX plug in Replacement, Battery: paso 1, imagen 1 de 1
    • To gain access to the 6 bottom screws remove the following. Remove the adhered 4 corner foam pads on the bottom of the speaker using the blue plastic opening tool to reveal the screws underneath. Remove the adhered 2 center plastic squares.
    • Make sure the speaker is unplugged and powered down before doing any work on the device.
  2. Sony SRS-X5 USB/AUX plug in Replacement: paso 2, imagen 1 de 2 Sony SRS-X5 USB/AUX plug in Replacement: paso 2, imagen 2 de 2
    • Unscrew the six 6mm screws with a Phillips head #1 screwdriver.
    • Remove the bottom panel of the speaker.
  3. Sony SRS-X5 USB/AUX plug in Replacement: paso 3, imagen 1 de 1
    • Unplug the battery by gently pinching the plastic end connected to the smaller board and pull away.
    • Remove the battery.
  4. Sony SRS-X5 USB/AUX plug in Replacement, Speaker: paso 4, imagen 1 de 1
    • To remove the speaker grill, first push down slightly on the 2 plastic hook tabs to release them, then push the middle plastic screw tab out.
  5. Sony SRS-X5 USB/AUX plug in Replacement: paso 5, imagen 1 de 1
    • Remove the eight 0.5mm Phillips #1 screws from the speaker panel.
  6. Sony SRS-X5 USB/AUX plug in Replacement: paso 6, imagen 1 de 2 Sony SRS-X5 USB/AUX plug in Replacement: paso 6, imagen 2 de 2
    • Using the plastic opening tool, flip open the speaker panel.
  7. Sony SRS-X5 USB/AUX plug in Replacement: paso 7, imagen 1 de 3 Sony SRS-X5 USB/AUX plug in Replacement: paso 7, imagen 2 de 3 Sony SRS-X5 USB/AUX plug in Replacement: paso 7, imagen 3 de 3
    • Unplug the 6-pin speaker connector and 2-pin microphone connector from the motherboard by squeezing the sides of the plastic ends.
  8. Sony SRS-X5 USB/AUX plug in Replacement, Bluetooth: paso 8, imagen 1 de 2 Sony SRS-X5 USB/AUX plug in Replacement, Bluetooth: paso 8, imagen 2 de 2
    • Unplug the cord connected to the motherboard by squeezing the plastic sides.
  9. Sony SRS-X5 USB/AUX plug in Replacement: paso 9, imagen 1 de 1
    • Gently tug on the plastic ribbon connected to the bottom side of the speaker to unplug it.
  10. Sony SRS-X5 USB/AUX plug in Replacement: paso 10, imagen 1 de 1
    • Remove the motherboard.
  11. Sony SRS-X5 USB/AUX plug in Replacement, USB/AUX plug in: paso 11, imagen 1 de 2 Sony SRS-X5 USB/AUX plug in Replacement, USB/AUX plug in: paso 11, imagen 2 de 2
    • Using the Phillips #1 screwdriver, remove the two 6mm screws holding the AUX board in place.
  12. Sony SRS-X5 USB/AUX plug in Replacement: paso 12, imagen 1 de 1
    • Remove the aux board. Be careful as the board might need some wiggling to get out.
Conclusión
Una persona más ha completado esta guía.
2 comentarios
hi there, where can i buy aux board for replacement? thank you
Khánh Trần - Contestar
Donde puedo conseguir la tarjeta?
Alan Castaneda - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 1,619
