Saltar al contenido principal
Sony SRS-X5 Speaker Replacement
Qué necesitas
  1. Sony SRS-X5 Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • To gain access to the 6 bottom screws remove the following. Remove the adhered 4 corner foam pads on the bottom of the speaker using the blue plastic opening tool to reveal the screws underneath. Remove the adhered 2 center plastic squares.
    • Make sure the speaker is unplugged and powered down before doing any work on the device.
  2. Sony SRS-X5 Speaker Replacement: paso 2, imagen 1 de 2 Sony SRS-X5 Speaker Replacement: paso 2, imagen 2 de 2
    • Unscrew the six 6mm screws with a Phillips head #1 screwdriver.
    • Remove the bottom panel of the speaker.
  3. Sony SRS-X5 Speaker Replacement: paso 3, imagen 1 de 1
    • Unplug the battery by gently pinching the plastic end connected to the smaller board and pull away.
    • Remove the battery.
  4. Sony SRS-X5 Speaker Replacement, Speaker: paso 4, imagen 1 de 1
    • To remove the speaker grill, first push down slightly on the 2 plastic hook tabs to release them, then push the middle plastic screw tab out.
  5. Sony SRS-X5 Speaker Replacement: paso 5, imagen 1 de 1
    • Remove the eight 0.5mm Phillips #1 screws from the speaker panel.
  6. Sony SRS-X5 Speaker Replacement: paso 6, imagen 1 de 2 Sony SRS-X5 Speaker Replacement: paso 6, imagen 2 de 2
    • Using the plastic opening tool, flip open the speaker panel.
  7. Sony SRS-X5 Speaker Replacement: paso 7, imagen 1 de 3 Sony SRS-X5 Speaker Replacement: paso 7, imagen 2 de 3 Sony SRS-X5 Speaker Replacement: paso 7, imagen 3 de 3
    • Unplug the 6-pin speaker connector and 2-pin microphone connector from the motherboard by squeezing the sides of the plastic ends.
Conclusión
5 personas más completaron esta guía.
10 comentarios
Help :)
Where can i buy a New speaker ?
Best regard Olav
olavfberge - Contestar
lol everywhere i go to find the replacement speaker i find more people trying to find it…. really want to fix my speaker..ffs
bollebaab-bouwer -
is there not a single soul that know the answer, why is this so hard to find out. im starting a company in loose speaker cones
bollebaab-bouwer -
Excellent!!! Thank you : )
Mick Talmadge - Contestar
Many thanks. Now I just need to find a replacement speaker!
Lesley Packwood - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 40
Todo El Tiempo: 4,047
