Saltar al contenido principal
Sony SRS-X3 Battery Charging Port Replacement
Qué necesitas
  1. Sony SRS-X3 Battery Charging Port Replacement, Battery Charging Port: paso 1, imagen 1 de 1
    • Remove the 6 10mm Philips head screws shown, using a PH1 screwdriver
  2. Sony SRS-X3 Battery Charging Port Replacement: paso 2, imagen 1 de 1
    • Remove the 5 8mm Philips head screws shown. These are holding the battery and the green circuit board in.
  3. Sony SRS-X3 Battery Charging Port Replacement: paso 3, imagen 1 de 1
    • Lift the battery pack and circuit board out of the housing and locate the wires and ribbon connector shown in the figure.
  4. Sony SRS-X3 Battery Charging Port Replacement: paso 4, imagen 1 de 2 Sony SRS-X3 Battery Charging Port Replacement: paso 4, imagen 2 de 2
    • Remove the ribbon connector and the connector from the battery pack (Note: These connectors are not easy to remove. Force may be necessary but the connectors are durable)
    • After the connections are remove you are free to replace the circuit board.
Conclusión
5 personas más completaron esta guía.
11 comentarios
Bradley, this is a SONY 40BKB537U-CNF2G board….where can I get one? The mini charge port is bad on mine and v difficult to replace.
Thanks
michael ruse - Contestar
Where can I buy the whole circuit board to replace the Charging port
Sony Mini speaker SRS - X3
40BKB537U - CNF2G
charging port
Morgan -
Where can I buy circuit board To replace charging port Sony Mini speaker SRS - X3
40BKB537U-CNF2G
Morgan -
Hi Michael, did you find a replacement board? I need to replace mine as well.
Julie Miller -
I have all the part of this speaker. Email me to negotiate! Kennyportillo99@gmail.com
kennycontreras44 -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 27
Todo El Tiempo: 6,661
