Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Sony Reader Touch Edition PRS-600 Power Button Replacement
Qué necesitas
  1. Sony Reader Touch Edition PRS-600 Power Button Replacement, Back Panel: paso 1, imagen 1 de 1
    • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
  2. Sony Reader Touch Edition PRS-600 Power Button Replacement: paso 2, imagen 1 de 1
    • Slide the back cover off by pushing it to the left, away from the side that held the screws.
    • Remove the cover.
  3. Sony Reader Touch Edition PRS-600 Power Button Replacement: paso 3, imagen 1 de 1
    • This is what the device should look like once the back cover panel has been removed.
  4. Sony Reader Touch Edition PRS-600 Power Button Replacement, Battery: paso 4, imagen 1 de 1
    • Once the back cover has been removed locate the battery in the bottom right corner of the device.
    • Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
  5. Sony Reader Touch Edition PRS-600 Power Button Replacement: paso 5, imagen 1 de 1
    • Use the flat end of the spudger to pry the battery out of its holder. There may be glue holding it in place.
  6. Sony Reader Touch Edition PRS-600 Power Button Replacement, Power Button: paso 6, imagen 1 de 1
    • Remove the stylus from the device.
  7. Sony Reader Touch Edition PRS-600 Power Button Replacement: paso 7, imagen 1 de 3 Sony Reader Touch Edition PRS-600 Power Button Replacement: paso 7, imagen 2 de 3 Sony Reader Touch Edition PRS-600 Power Button Replacement: paso 7, imagen 3 de 3
    • Using the Phillips screwdriver remove the 1.4 mm screw from the top panel.
    • Using the same screwdriver, remove the 1.4 mm screw from the back of the device.
    • Pry apart off the top panel of the device.
Conclusión
Equipo
Clemson, Team 1-4, Benson Fall 2014 Miembro de Clemson, Team 1-4, Benson Fall 2014
CLEM-BENSON-F14S1G4
Miembros de 4
22 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 22
Ultimos 30 días: 60
Todo El Tiempo: 910
