Saltar al contenido principal
Sony Radio CD player and cassette player CFD-S05 Optical Pickup Unit Replacement
Qué necesitas
  1. Sony Radio CD player and cassette player CFD-S05 Optical Pickup Unit Replacement, Sony Radio Model CFD S05 Prerequisite steps Replacement: paso 1, imagen 1 de 1
    • Unscrew the screws on the top of the radio.
  2. Sony Radio CD player and cassette player CFD-S05 Optical Pickup Unit Replacement: paso 2, imagen 1 de 2 Sony Radio CD player and cassette player CFD-S05 Optical Pickup Unit Replacement: paso 2, imagen 2 de 2
    • Open the CD and cassette doors and remove the screws in the compartments.
    • To open the CD door push on the bottom left corner of the CD door. To open the cassette door push the button that is to the left of the pause button.
  3. Sony Radio CD player and cassette player CFD-S05 Optical Pickup Unit Replacement: paso 3, imagen 1 de 1
    • Flip the radio upside down and remove the battery cover. Unscrew the one screw below the batteries.
  4. Sony Radio CD player and cassette player CFD-S05 Optical Pickup Unit Replacement: paso 4, imagen 1 de 1
    • Remove the top of the radio enough to access the wires for removal.
    • Do not forcefully remove the whole top piece of the radio! There will be wires connected to the top cover and circuit board.
  5. Sony Radio CD player and cassette player CFD-S05 Optical Pickup Unit Replacement: paso 5, imagen 1 de 1
    • Remove all of the wires that are connected to both the circuit board and the underside of the top of the radio by pulling them where they are connected
    • This should include three sets of red and white wires, one set of white wires, one set of black wires, and two ribbon wires. Some cannot be disconnected from the top piece of the radio. Disconnect these plugs from the circuit board.
  6. Sony Radio CD player and cassette player CFD-S05 Optical Pickup Unit Replacement, Optical Pickup Unit: paso 6, imagen 1 de 1
    • Unscrew the three screws on the optical pick up unit, which is on the underside of the cover
    • The optical pick up unit is located directly beneath the CD player on the underside of the top face of the radio.
  7. Sony Radio CD player and cassette player CFD-S05 Optical Pickup Unit Replacement: paso 7, imagen 1 de 1
    • Insert the new optical pick up unit.
    • Make sure it is aligned properly.
  8. Sony Radio CD player and cassette player CFD-S05 Optical Pickup Unit Replacement: paso 8, imagen 1 de 1
    • Screw in the new optical pick up unit.
Conclusión
Una persona más ha completado esta guía.
Ian Nussman
Miembro Desde 10/25/13
959 Reputación
6 Guías creadas
Equipo
UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2013 Miembro de UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S2G5
2 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 3,000
