Saltar al contenido principal
Sony RDR HX750 HX950 Disassembly
Qué necesitas
  1. Sony RDR HX750 HX950 Disassembly, Remove cover: paso 1, imagen 1 de 3 Sony RDR HX750 HX950 Disassembly, Remove cover: paso 1, imagen 2 de 3 Sony RDR HX750 HX950 Disassembly, Remove cover: paso 1, imagen 3 de 3
    • Remove the screws from the back and sides of the top cover.
  2. Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: paso 2, imagen 1 de 3 Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: paso 2, imagen 2 de 3 Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: paso 2, imagen 3 de 3
    • Remove the four screws that secure the hard drive mounting bracket to the bottom of the unit.
    • Unplug the two cables from the rear of the hard drive.
    • Remove the four screws from the bottom of the hard drive mounting bracket.
  3. Sony RDR HX750 HX950 Disassembly, Remove DVD player: paso 3, imagen 1 de 3 Sony RDR HX750 HX950 Disassembly, Remove DVD player: paso 3, imagen 2 de 3 Sony RDR HX750 HX950 Disassembly, Remove DVD player: paso 3, imagen 3 de 3
    • Remove the screws from the DVD cover
    • Remove the screws from the plastic cable holder
  4. Sony RDR HX750 HX950 Disassembly, Remove front Panel: paso 4, imagen 1 de 3 Sony RDR HX750 HX950 Disassembly, Remove front Panel: paso 4, imagen 2 de 3 Sony RDR HX750 HX950 Disassembly, Remove front Panel: paso 4, imagen 3 de 3
    • Insert the paper under each "click" to remove the front panel.
    • Once each "click" is loose, push the front panel gently.
    • The table of the compact disk has a little plastic piece in front that goes up to come out with a "click"
  5. Sony RDR HX750 HX950 Disassembly, Remove  DVD block: paso 5, imagen 1 de 3 Sony RDR HX750 HX950 Disassembly, Remove  DVD block: paso 5, imagen 2 de 3 Sony RDR HX750 HX950 Disassembly, Remove  DVD block: paso 5, imagen 3 de 3
    • Unplug the cables show in photo.
    • Disconnect the cable hidden on the side.
    • Remove the piece on the cd reader
  6. Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: paso 6, imagen 1 de 3 Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: paso 6, imagen 2 de 3 Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: paso 6, imagen 3 de 3
    • Under the DVD block, remove the screws as shown.
    • Remove the screws on the board.
    • Now the laser can be accessed.
  7. Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: paso 7, imagen 1 de 3 Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: paso 7, imagen 2 de 3 Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: paso 7, imagen 3 de 3
    • Inserir instruções aqui.
Conclusión
To open this dvd recorder folow this tutorial
2 personas más completaron esta guía.
Cafony
Miembro Desde 02/17/15
687 Reputación
4 Guías creadas
Un comentario
Hello,HX950 work only with hdd 250Gb,or another,with 500 or 1000Gb ???
Cornelus - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 48
Todo El Tiempo: 5,376
