Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu PlayStation, utiliza nuestros manuales de servicio .
  1. Sony PlayStation SCPH-9002 Teardown, Sony PlayStation SCPH-9002 Teardown: paso 1, imagen 1 de 2 Sony PlayStation SCPH-9002 Teardown, Sony PlayStation SCPH-9002 Teardown: paso 1, imagen 2 de 2
    • Here's the PS1.
    • Turn the PS1 over and remove the six screws.
    • Note: part number +BV 3X14
  2. Sony PlayStation SCPH-9002 Teardown: paso 2, imagen 1 de 1
    • Remove the top cover. It's very easy.
  3. Sony PlayStation SCPH-9002 Teardown: paso 3, imagen 1 de 1
    • Disconnect both CD-ROM connectors.
    • CD connector one and the socket it connects to.
    • CD connector two and the socket it connects to.
    • Note: part number DEVICE OPTICAL KSM-440AEM
  4. Sony PlayStation SCPH-9002 Teardown: paso 4, imagen 1 de 2 Sony PlayStation SCPH-9002 Teardown: paso 4, imagen 2 de 2
    • Remove the CD-ROM reader. You should be able to pull it out gently, although you may have to wiggle it around a bit to loosen the rubber holders.
  5. Sony PlayStation SCPH-9002 Teardown: paso 5, imagen 1 de 1
    • Detach both cables. They go to the power supply and to the memory cards and controller connectors.
  6. Sony PlayStation SCPH-9002 Teardown: paso 6, imagen 1 de 1
    • Remove the four screws and the metal cover.
  7. Sony PlayStation SCPH-9002 Teardown: paso 7, imagen 1 de 2 Sony PlayStation SCPH-9002 Teardown: paso 7, imagen 2 de 2
    • Now you have the motherboard!
    • And the power supply.
    • Remove the four screws from the motherboard and the power supply.
  8. Sony PlayStation SCPH-9002 Teardown: paso 8, imagen 1 de 1
    • Once the screws are removed, remove the power supply.
  9. Sony PlayStation SCPH-9002 Teardown: paso 9, imagen 1 de 1
    • Remove the motherboard, and both of the screws from the memory card/ controller connection mechanism.
  10. Sony PlayStation SCPH-9002 Teardown: paso 10, imagen 1 de 1
    • Now, you have all your PlayStation 1 parts!
    • Main Board
    • Lower Casing
    • EMI Shield
    • Power Supply
    • Disk Reader
    • Memory Card/ Controller Mechanism
imacg517
Miembro Desde 05/06/10
182 Reputación
1 Guía escrita
Un comentario
That’s a PAL PS1. May be different from NTSC models.
Daniel Powers - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 28
Ultimos 30 días: 110
Todo El Tiempo: 27,879
