Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Sony PlayStation Camera Microphone Array Replacement
Qué necesitas
  1. Sony PlayStation Camera Microphone Array Replacement, Microphone Array: paso 1, imagen 1 de 2 Sony PlayStation Camera Microphone Array Replacement, Microphone Array: paso 1, imagen 2 de 2
    • Separate the camera from the camera stand to gain access to the bottom of the camera.
    Pregunta a FixBot
  2. Sony PlayStation Camera Microphone Array Replacement: paso 2, imagen 1 de 2 Sony PlayStation Camera Microphone Array Replacement: paso 2, imagen 2 de 2
    • With the PH000 sized screwdriver, remove the two 6.5mm Phillips #000 screws located under the stand connection point, where the cable enters the case.
    Pregunta a FixBot
  3. Sony PlayStation Camera Microphone Array Replacement: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Using tweezers, remove the cap holding the cable grommet in place.
    Pregunta a FixBot
  4. Sony PlayStation Camera Microphone Array Replacement: paso 4, imagen 1 de 1
    • Using the tweezers, remove both poly-carbonate lens coverplates.
    • Lift the coverplates slowly, to ensure they do not crack, or break.
    Pregunta a FixBot
  5. Sony PlayStation Camera Microphone Array Replacement: paso 5, imagen 1 de 2 Sony PlayStation Camera Microphone Array Replacement: paso 5, imagen 2 de 2
    • Using the PH0 sized screwdriver, remove two 3.2mm Phillips #0 screws, located under the coverplates.
    Pregunta a FixBot
  6. Sony PlayStation Camera Microphone Array Replacement: paso 6, imagen 1 de 1
    • Using extreme care, separate the front of the case, from the back with a metal spudger, or pry tool. The case will scratch easily.
    • The case joints can be hard to spot. They appear as a very fine line in the plastic. Start with light pressure until the seam parts, allowing the pry tool to work.
    Pregunta a FixBot
  7. Sony PlayStation Camera Microphone Array Replacement: paso 7, imagen 1 de 2 Sony PlayStation Camera Microphone Array Replacement: paso 7, imagen 2 de 2
    • Using the PH0 sized screwdriver, remove the four 4.5mm Phillips #0 screws securing the circuit assembly to the device housing.
    Pregunta a FixBot
  8. Sony PlayStation Camera Microphone Array Replacement: paso 8, imagen 1 de 3 Sony PlayStation Camera Microphone Array Replacement: paso 8, imagen 2 de 3 Sony PlayStation Camera Microphone Array Replacement: paso 8, imagen 3 de 3
    • Lift the motherboard and frame from the plastic housing.
    • Disconnect the camera cable from the motherboard.
    Pregunta a FixBot
  9. Sony PlayStation Camera Microphone Array Replacement: paso 9, imagen 1 de 2 Sony PlayStation Camera Microphone Array Replacement: paso 9, imagen 2 de 2
    • Using the PH0 sized screwdriver, remove the six 4.2mm Phillips #0 screws securing the motherboard to the metal frame.
    Pregunta a FixBot
  10. Sony PlayStation Camera Microphone Array Replacement: paso 10, imagen 1 de 2 Sony PlayStation Camera Microphone Array Replacement: paso 10, imagen 2 de 2
    • Using a plastic opening tool, disconnect the microphone array connector from the motherboard.
    Pregunta a FixBot
  11. Sony PlayStation Camera Microphone Array Replacement: paso 11, imagen 1 de 3 Sony PlayStation Camera Microphone Array Replacement: paso 11, imagen 2 de 3 Sony PlayStation Camera Microphone Array Replacement: paso 11, imagen 3 de 3
    • Using fine point tweezers, grab hold of each microphone, one at a time, and lift from the plastic frame.
    • Using care to not damage the wires, remove microphone array from the retaining tabs on the plastic frame.
    Pregunta a FixBot
Conclusión
Una persona más ha completado esta guía.
Joshua Gates
Miembro Desde 02/15/17
268 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 5-5, Passmore Spring 2017 Miembro de USF Tampa, Team 5-5, Passmore Spring 2017
USFT-PASSMORE-S17S5G5
Miembros de 3
4 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 91
Todo El Tiempo: 7,693
