Saltar al contenido principal
Sony PlayStation 3D Display Power Port Replacement
Qué necesitas
  1. Sony PlayStation 3D Display Power Port Replacement, Rear Case: paso 1, imagen 1 de 2 Sony PlayStation 3D Display Power Port Replacement, Rear Case: paso 1, imagen 2 de 2
    • Remove the base by pushing in the button and sliding out the unit.
  2. Sony PlayStation 3D Display Power Port Replacement: paso 2, imagen 1 de 3 Sony PlayStation 3D Display Power Port Replacement: paso 2, imagen 2 de 3 Sony PlayStation 3D Display Power Port Replacement: paso 2, imagen 3 de 3
    • Remove USB port cover from back plate with a metal spudger.
    • This will prevent the cover from falling under the back plate once it is removed.
  3. Sony PlayStation 3D Display Power Port Replacement: paso 3, imagen 1 de 2 Sony PlayStation 3D Display Power Port Replacement: paso 3, imagen 2 de 2
    • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
    • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
    • These screws have different threads and need to be kept separate.
  4. Sony PlayStation 3D Display Power Port Replacement: paso 4, imagen 1 de 3 Sony PlayStation 3D Display Power Port Replacement: paso 4, imagen 2 de 3 Sony PlayStation 3D Display Power Port Replacement: paso 4, imagen 3 de 3
    • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
    • Be gentle to avoid breaking the plastic clips which hold the plate.
    • Once separated the plate easily lifts off.
  5. Sony PlayStation 3D Display Power Port Replacement, Power Port: paso 5, imagen 1 de 3 Sony PlayStation 3D Display Power Port Replacement, Power Port: paso 5, imagen 2 de 3 Sony PlayStation 3D Display Power Port Replacement, Power Port: paso 5, imagen 3 de 3
    • With the Phillips #02 screwdriver, remove the two 5mm length x 7mm head screws from the left and right side of the power port plate.
  6. Sony PlayStation 3D Display Power Port Replacement: paso 6, imagen 1 de 3 Sony PlayStation 3D Display Power Port Replacement: paso 6, imagen 2 de 3 Sony PlayStation 3D Display Power Port Replacement: paso 6, imagen 3 de 3
    • Remove the power port by depressing the white tab attached to the wires.
Conclusión
Una persona más ha completado esta guía.
Logan Simon
Miembro Desde 10/08/15
234 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 12-16, Maness Fall 2015 Miembro de Cal Poly, Team 12-16, Maness Fall 2015
CPSU-MANESS-F15S12G16
Miembros de 4
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 37
Todo El Tiempo: 1,642
