Saltar al contenido principal
Sony PlayStation 3D Display Control Buttons Replacement
Qué necesitas
  1. Sony PlayStation 3D Display Control Buttons Replacement, Rear Case: paso 1, imagen 1 de 2 Sony PlayStation 3D Display Control Buttons Replacement, Rear Case: paso 1, imagen 2 de 2
    • Remove the base by pushing in the button and sliding out the unit.
  2. Sony PlayStation 3D Display Control Buttons Replacement: paso 2, imagen 1 de 3 Sony PlayStation 3D Display Control Buttons Replacement: paso 2, imagen 2 de 3 Sony PlayStation 3D Display Control Buttons Replacement: paso 2, imagen 3 de 3
    • Remove USB port cover from back plate with a metal spudger.
    • This will prevent the cover from falling under the back plate once it is removed.
  3. Sony PlayStation 3D Display Control Buttons Replacement: paso 3, imagen 1 de 2 Sony PlayStation 3D Display Control Buttons Replacement: paso 3, imagen 2 de 2
    • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
    • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
    • These screws have different threads and need to be kept separate.
  4. Sony PlayStation 3D Display Control Buttons Replacement: paso 4, imagen 1 de 3 Sony PlayStation 3D Display Control Buttons Replacement: paso 4, imagen 2 de 3 Sony PlayStation 3D Display Control Buttons Replacement: paso 4, imagen 3 de 3
    • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
    • Be gentle to avoid breaking the plastic clips which hold the plate.
    • Once separated the plate easily lifts off.
  5. Sony PlayStation 3D Display Control Buttons Replacement, Control Buttons: paso 5, imagen 1 de 1
    • With the Phillips #01 screwdriver, remove the two 5 mm length x 7 mm head screws from the top and bottom of the control button bar.
  6. Sony PlayStation 3D Display Control Buttons Replacement: paso 6, imagen 1 de 2 Sony PlayStation 3D Display Control Buttons Replacement: paso 6, imagen 2 de 2
    • Detach the control button bar by depressing the small white tab that connects the bar to its wires.
Conclusión
Una persona más ha completado esta guía.
Tia McNaughton
Miembro Desde 10/01/15
379 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 12-16, Maness Fall 2015 Miembro de Cal Poly, Team 12-16, Maness Fall 2015
CPSU-MANESS-F15S12G16
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 517
