Saltar al contenido principal
Sony PS-LX300USB Dust Cover Replacement
Qué necesitas
  1. Sony PS-LX300USB Dust Cover Replacement, Dust Cover: paso 1, imagen 1 de 1
    • Turn the turntable around so that the back side is visible.
  2. Sony PS-LX300USB Dust Cover Replacement: paso 2, imagen 1 de 2 Sony PS-LX300USB Dust Cover Replacement: paso 2, imagen 2 de 2
    • Begin by releasing the left latch. Apply downward pressure to the square, black button using a flathead screw driver.
    • Once the latch is released, lift upward.
    • Use your left hand to hold the left side of the dust cover above the latch. This ensures the latch does not reconnect.
  3. Sony PS-LX300USB Dust Cover Replacement: paso 3, imagen 1 de 1
    • Use a flat head screw driver to apply pressure to the black square button on the right side.
  4. Sony PS-LX300USB Dust Cover Replacement: paso 4, imagen 1 de 2 Sony PS-LX300USB Dust Cover Replacement: paso 4, imagen 2 de 2
    • Once both the right and left buttons are released, pull the dust cover upwards.
    • The dust cover is now disconnected and ready for replacement.
Conclusión
Sean
Miembro Desde 09/27/17
109 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S8-G3, Banghart Fall 2017 Miembro de Cal Poly, Team S8-G3, Banghart Fall 2017
CPSU-BANGHART-F17S8G3
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 18
Todo El Tiempo: 2,295
