Saltar al contenido principal
Sony NEX-7 Lens Mount Replacement
Qué necesitas
  1. Sony NEX-7 Lens Mount Replacement, Battery: paso 1, imagen 1 de 2 Sony NEX-7 Lens Mount Replacement, Battery: paso 1, imagen 2 de 2
    • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
    • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
  2. Sony NEX-7 Lens Mount Replacement: paso 2, imagen 1 de 1
    • Flip the camera over such that the power switch points down.
    • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
  3. Sony NEX-7 Lens Mount Replacement: paso 3, imagen 1 de 1
    • With the battery door open, push the blue lever in the battery compartment to release the battery.
  4. Sony NEX-7 Lens Mount Replacement, SD card: paso 4, imagen 1 de 1
    • To the left of the battery compartment, the SD card needs to be pushed down slightly with your fingers, which will cause the card to eject.
    • Pull the card out with your fingers.
  5. Sony NEX-7 Lens Mount Replacement, Lens: paso 5, imagen 1 de 2 Sony NEX-7 Lens Mount Replacement, Lens: paso 5, imagen 2 de 2
    • First, turn the camera upside down.
    • Press the button located next to silver lens mount and rotate the lens counterclockwise.
    • Pull the lens away from the camera body.
    • After removing the lens, replace the lens or attach the body cap as soon as possible to prevent damage to the shutter.
  6. Sony NEX-7 Lens Mount Replacement, Lens Mount: paso 6, imagen 1 de 1
    • With the front of the camera facing you, remove the four silver #00 Phillips screws from the metal lens mount.
  7. Sony NEX-7 Lens Mount Replacement: paso 7, imagen 1 de 1
    • Remove these three layers from the lens mount with your finger or by turning the camera face down.
  8. Sony NEX-7 Lens Mount Replacement: paso 8, imagen 1 de 1
    • Remove the two newly visible #00 screws within the metal ring.
  9. Sony NEX-7 Lens Mount Replacement: paso 9, imagen 1 de 1
    • Remove the final metal ring from the mount.
Conclusión
5 personas más completaron esta guía.
Jay Miley
Miembro Desde 04/22/14
5,042 Reputación
13 Guías creadas
Equipo
Cal Poly, Team 10-55, Amido Spring 2014 Miembro de Cal Poly, Team 10-55, Amido Spring 2014
CPSU-AMIDO-S14S10G55
4 Miembros
31 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 2,190
