Saltar al contenido principal
Sony NEX-7 Battery Replacement
  1. Sony NEX-7 Battery Replacement, Battery: paso 1, imagen 1 de 2 Sony NEX-7 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
    • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
  2. Sony NEX-7 Battery Replacement: paso 2, imagen 1 de 1
    • Flip the camera over such that the power switch points down.
    • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
  3. Sony NEX-7 Battery Replacement: paso 3, imagen 1 de 1
    • With the battery door open, push the blue lever in the battery compartment to release the battery.
Conclusión
To replace the battery, fit it in the slot, then close and lock the door.
2 personas más completaron esta guía.
Tyler
Miembro Desde 04/22/14
569 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 10-55, Amido Spring 2014 Miembro de Cal Poly, Team 10-55, Amido Spring 2014
CPSU-AMIDO-S14S10G55
4 Miembros
31 Guías creadas
Un comentario
I’ve done this about a million times. :)
Martin Hurley - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 15
Ultimos 30 días: 30
Todo El Tiempo: 2,056
