Saltar al contenido principal
Sony NEX-5T LCD Screen Replacement
Qué necesitas
  1. Sony NEX-5T LCD Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Open the battery compartment by sliding the lock to the right.
  2. Sony NEX-5T LCD Screen Replacement: paso 2, imagen 1 de 1
    • Push in the blue lever.
    • The battery is on a spring so make sure you have control over it, or it might fly out.
  3. Sony NEX-5T LCD Screen Replacement: paso 3, imagen 1 de 2 Sony NEX-5T LCD Screen Replacement: paso 3, imagen 2 de 2
    • Pull the battery out.
  4. Sony NEX-5T LCD Screen Replacement, LCD Screen: paso 4, imagen 1 de 2 Sony NEX-5T LCD Screen Replacement, LCD Screen: paso 4, imagen 2 de 2
    • Pick up the device with the LCD screen facing you.
    • While gripping with one hand, lift up on the LCD screen to reveal screws underneath
  5. Sony NEX-5T LCD Screen Replacement: paso 5, imagen 1 de 1
    • Unscrew and remove the eight1.2mm Phillips 00 screws.
    • Make sure to apply adequate pressure while unscrewing these screws to avoid stripping them.
    • Removing these screws will loosen the plates which cover the LCD screen.
  6. Sony NEX-5T LCD Screen Replacement: paso 6, imagen 1 de 2 Sony NEX-5T LCD Screen Replacement: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Remove the black plate by using your fingers or tweezers.
    • This plate may be difficult to remove. Try to manipulate the position of the screen in order to make removal easier.
  7. Sony NEX-5T LCD Screen Replacement: paso 7, imagen 1 de 3 Sony NEX-5T LCD Screen Replacement: paso 7, imagen 2 de 3 Sony NEX-5T LCD Screen Replacement: paso 7, imagen 3 de 3
    • Remove the second plate by pulling it away from the camera. You can use tweezers or your fingers for this step.
  8. Sony NEX-5T LCD Screen Replacement: paso 8, imagen 1 de 3 Sony NEX-5T LCD Screen Replacement: paso 8, imagen 2 de 3 Sony NEX-5T LCD Screen Replacement: paso 8, imagen 3 de 3
    • Rotate the camera so the lens is facedown and the power button is pointing away from you.
    • Remove the two 1.2mm Phillips 00 screws shown in the image.
  9. Sony NEX-5T LCD Screen Replacement: paso 9, imagen 1 de 2 Sony NEX-5T LCD Screen Replacement: paso 9, imagen 2 de 2
    • Remove the 2 metal side coverings from the side of the LCD.
    • You may have to manipulate the position of the LCD screen to allow easier removal.
  10. Sony NEX-5T LCD Screen Replacement: paso 10, imagen 1 de 3 Sony NEX-5T LCD Screen Replacement: paso 10, imagen 2 de 3 Sony NEX-5T LCD Screen Replacement: paso 10, imagen 3 de 3
    • Use tweezers to peel back the small black film.
  11. Sony NEX-5T LCD Screen Replacement: paso 11, imagen 1 de 3 Sony NEX-5T LCD Screen Replacement: paso 11, imagen 2 de 3 Sony NEX-5T LCD Screen Replacement: paso 11, imagen 3 de 3
    • Rotate the camera, and lift up on the LCD screen.
    • Be careful you do not pull the LCD too far from the camera because wires are still attached.
    • This will reveal a large black rectangular film which you can peel back with tweezers.
  12. Sony NEX-5T LCD Screen Replacement: paso 12, imagen 1 de 3 Sony NEX-5T LCD Screen Replacement: paso 12, imagen 2 de 3 Sony NEX-5T LCD Screen Replacement: paso 12, imagen 3 de 3
    • Rotate the camera and use your fingers or tweezers to disconnect the first wire.
    • Remove the wire gently to avoid damage.
  13. Sony NEX-5T LCD Screen Replacement: paso 13, imagen 1 de 3 Sony NEX-5T LCD Screen Replacement: paso 13, imagen 2 de 3 Sony NEX-5T LCD Screen Replacement: paso 13, imagen 3 de 3
    • Lift the tab of the ZIF connector and pull the wire away from the motherboard.
  14. Sony NEX-5T LCD Screen Replacement: paso 14, imagen 1 de 1
    • You may remove the loose black film from the back of the LCD screen.
    • When purchasing a new LCD screen be mindful that some do not come with the original plastic frame. You may have to separate these pieces by pushing the LCD out of the frame from behind.
    • It takes force to break the adhesive bond, but be mindful to not break the frame when applying force.
    • Upon reassembly place the tape on the inner edges of the LCD frame. When pressed back together there may be excess, use a knife to remove this overlap.
Conclusión
5 personas más completaron esta guía.
Robert Phillips
Miembro Desde 03/02/17
321 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S13-G2, Cagle Spring 2017 Miembro de USF Tampa, Team S13-G2, Cagle Spring 2017
USFT-CAGLE-S17S13G2
3 Miembros
12 Guías creadas
3 comentarios
Where does one find the replacement screen? I’m in sore need of this myself.
Will Evans - Contestar
I was able to get the screen working with a new replacement, but without the double-sided tape it feels like a cludge.
where did you find the screen, if i may?
Haziq Husni -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 40
Todo El Tiempo: 3,304
