Saltar al contenido principal
Sony NEX-5R Rear Case Replacement
Qué necesitas
  1. Sony NEX-5R Rear Case Replacement, Front Case: paso 1, imagen 1 de 2 Sony NEX-5R Rear Case Replacement, Front Case: paso 1, imagen 2 de 2
    • Open the battery pack door by moving the slider to "OPEN".
    • Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
  2. Sony NEX-5R Rear Case Replacement: paso 2, imagen 1 de 1
    • Remove the 3.25 mm exterior screw with a Phillips screwdriver.
  3. Sony NEX-5R Rear Case Replacement: paso 3, imagen 1 de 2 Sony NEX-5R Rear Case Replacement: paso 3, imagen 2 de 2
    • Use the spudger to raise the corner of the case from the camera.
    • One component of the front case should now be separate from the camera.
  4. Sony NEX-5R Rear Case Replacement, Rear Case: paso 4, imagen 1 de 1
    • Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
  5. Sony NEX-5R Rear Case Replacement: paso 5, imagen 1 de 1
    • Open the HDMI port, and remove the the two (3.5 mm) Phillips screws exposed on that side.
  6. Sony NEX-5R Rear Case Replacement: paso 6, imagen 1 de 1
    • Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
  7. Sony NEX-5R Rear Case Replacement: paso 7, imagen 1 de 1
    • Looking at the bottom of the camera, use the spudger to lift the rear case away from the camera body.
  8. Sony NEX-5R Rear Case Replacement: paso 8, imagen 1 de 2 Sony NEX-5R Rear Case Replacement: paso 8, imagen 2 de 2
    • Using the spudger again, carefully pry from the top of the camera to remove the back frame.
    • The back frame is fragile, so use the spudger gently.
  9. Sony NEX-5R Rear Case Replacement: paso 9, imagen 1 de 1
    • The back case should now be removed and look like this.
Conclusión
Una persona más ha completado esta guía.
Emily Trujillo
Miembro Desde 04/08/14
1,114 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 8-9, Regan Spring 2014 Miembro de Cal Poly, Team 8-9, Regan Spring 2014
CPSU-REGAN-S14S8G9
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 25
Todo El Tiempo: 2,521
