Saltar al contenido principal
Sony NEX-5R Lens Mount Replacement
Qué necesitas
  1. Sony NEX-5R Lens Mount Replacement, Lens Mount: paso 1, imagen 1 de 2 Sony NEX-5R Lens Mount Replacement, Lens Mount: paso 1, imagen 2 de 2
    • Hold lens and camera securely with two hands.
    • With the hand holding the camera, push down on the lens button. Twist the lens counterclockwise and pull out to release lens.
  2. Sony NEX-5R Lens Mount Replacement: paso 2, imagen 1 de 1
    • Using your screwdriver, remove the four (3.5 mm) Phillips screws on the front face of the lens mount.
    • Make sure to keep track of these screws and not misplace them.
  3. Sony NEX-5R Lens Mount Replacement: paso 3, imagen 1 de 1
    • Remove the silver plate by gently pinching with your fingers.
  4. Sony NEX-5R Lens Mount Replacement: paso 4, imagen 1 de 1
    • Now the black plate should be exposed. You can remove this again by gently pinching with your fingers and lifting up.
  5. Sony NEX-5R Lens Mount Replacement: paso 5, imagen 1 de 1
    • Using the tweezers, grab the thin silver ring and lift up.
  6. Sony NEX-5R Lens Mount Replacement: paso 6, imagen 1 de 1
    • The camera mount should now be barren and look like this.
Conclusión
Una persona más ha completado esta guía.
Emily Trujillo
Miembro Desde 04/08/14
1,114 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 8-9, Regan Spring 2014 Miembro de Cal Poly, Team 8-9, Regan Spring 2014
CPSU-REGAN-S14S8G9
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 2,516
