Saltar al contenido principal
Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement
Qué necesitas
  1. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement, Swivel: paso 1, imagen 1 de 1
    • Begin by laying the headphones down flat with the speakers facing up.
    • Be sure to unplug the headphones from any other devices.
  2. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: paso 2, imagen 1 de 2 Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: paso 2, imagen 2 de 2
    • Next, take out the screws that hold the front plate, using a J00 screwdriver.
    • Repeat for both the left and right screws.
    • These screws are very small. It is helpful to have a spot prepared to put the screws to avoid losing pieces.
  3. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: paso 3, imagen 1 de 1
    • Now that the screws have been removed, pull away the plastic casing that covers the swivel piece (directly above the speaker).
  4. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: paso 4, imagen 1 de 1
    • Now that the swivel piece is exposed, use a J00 screwdriver to unscrew the center screw.
    • Repeat this process on both sides if necessary.
    • This center screw is the piece that retains the swivel action, unscrew completely and remove to replace.
  5. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement, Swivel Plastic Cover: paso 5, imagen 1 de 1
    • With the swivel screw removed, remove the plastic casing.
  6. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: paso 6, imagen 1 de 1
    • Using a little amount of force, slide the plastic cover off of the headband.
  7. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: paso 7, imagen 1 de 1
    • Pull the plastic until the cover is fully removed.
Conclusión
Una persona más ha completado esta guía.
Un comentario
Necesito la pieza, dónde la compro?
lucas2188 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 11
Todo El Tiempo: 3,231
