Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Following this guides shows you how to remove the cassette lid from the device. Removing the cassette lid allows you to install a new one and enables you to remove the mechanism deck
Partes
No se especificaron partes.
  1. Using a spudger, apply pressure towards the back corner of the cassette compartment to the plastic tab directly behind the gold cone. Pushing the tab allows the hinge to be separated from the body of the device. The third picture shows the what the tab looks like when the device is disassembled, and illustrates the direction to apply pressure.
    • Using a spudger, apply pressure towards the back corner of the cassette compartment to the plastic tab directly behind the gold cone.
    • Pushing the tab allows the hinge to be separated from the body of the device.
    • The third picture shows the what the tab looks like when the device is disassembled, and illustrates the direction to apply pressure.
  2. El kit de herramientas esencial
    Las herramientas más útiles en nuestro kit más compacto.
    Compra ahora
    Compra ahora
  3. Next, use a plastic opening tool to pull the metal latch towards the speaker. The latch should be clear of the slot in the cassette lid.
    • Next, use a plastic opening tool to pull the metal latch towards the speaker.
    • The latch should be clear of the slot in the cassette lid.
    • Be careful not to bend the latch too far, as it may warp.
  4. Carefully lift the cassette lid, making sure the tab and latch are free from connection.
    • Carefully lift the cassette lid, making sure the tab and latch are free from connection.
Conclusión
Scott
Miembro Desde 21/01/12
1 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 10-34, Amido Winter 2012 Miembro de Cal Poly, Team 10-34, Amido Winter 2012
CPSU-AMIDO-W12S10G34
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 1,163
