Saltar al contenido principal
Sony ICF-C1iPMK2 Speaker Replacement
Qué necesitas
  1. Sony ICF-C1iPMK2 Speaker Replacement, Speaker: paso 1, imagen 1 de 2 Sony ICF-C1iPMK2 Speaker Replacement, Speaker: paso 1, imagen 2 de 2
    • Unscrew the 1 cm Phillips #00 screws.
    • Use spudger to loosen the back panel of the device.
  2. Sony ICF-C1iPMK2 Speaker Replacement: paso 2, imagen 1 de 3 Sony ICF-C1iPMK2 Speaker Replacement: paso 2, imagen 2 de 3 Sony ICF-C1iPMK2 Speaker Replacement: paso 2, imagen 3 de 3
    • This step contains ribbon cables. Be careful to not bend or rip these fragile cables, to protect your device.
    • Slowly pull the back panel off until it separated from the main panel.
    • Carefully unplug all of the ribbon cables connecting the back panel to the main panel.
  3. Sony ICF-C1iPMK2 Speaker Replacement: paso 3, imagen 1 de 3 Sony ICF-C1iPMK2 Speaker Replacement: paso 3, imagen 2 de 3 Sony ICF-C1iPMK2 Speaker Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Remove the power connector with a pair of ESD safe tweezers.
    • Remove the Aux port connector with a pair of ESD safe tweezers.
    • Slide the button panels out of the chassis.
  4. Sony ICF-C1iPMK2 Speaker Replacement: paso 4, imagen 1 de 3 Sony ICF-C1iPMK2 Speaker Replacement: paso 4, imagen 2 de 3 Sony ICF-C1iPMK2 Speaker Replacement: paso 4, imagen 3 de 3
    • Unscrew the four 1 cm Phillips #00 screws and remove the speaker cover.
    • Unscrew the 1 cm Phillips #00 screws holding the speaker in place.
    • Remove the old speaker and insert the new one.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 88
