Saltar al contenido principal
Sony ICF-C1iPMK2 Control Buttons Replacement
Qué necesitas
  1. Sony ICF-C1iPMK2 Control Buttons Replacement, Control Buttons: paso 1, imagen 1 de 3 Sony ICF-C1iPMK2 Control Buttons Replacement, Control Buttons: paso 1, imagen 2 de 3 Sony ICF-C1iPMK2 Control Buttons Replacement, Control Buttons: paso 1, imagen 3 de 3
    • Remove the 1 cm Phillips #00 head screws.
    • Use a plastic spudger to pry the back chassis away from the front.
  2. Sony ICF-C1iPMK2 Control Buttons Replacement: paso 2, imagen 1 de 3 Sony ICF-C1iPMK2 Control Buttons Replacement: paso 2, imagen 2 de 3 Sony ICF-C1iPMK2 Control Buttons Replacement: paso 2, imagen 3 de 3
    • This step contains ribbon cables. Be careful to not bend or rip these fragile cables, to protect your device.
    • Open the back chassis.
    • Remove the top ribbon cable by pulling it straight out of the port.
  3. Sony ICF-C1iPMK2 Control Buttons Replacement: paso 3, imagen 1 de 3 Sony ICF-C1iPMK2 Control Buttons Replacement: paso 3, imagen 2 de 3 Sony ICF-C1iPMK2 Control Buttons Replacement: paso 3, imagen 3 de 3
    • Disconnect the power connector.
    • Disconnect the AUX port connector.
    • Slide the buttons out of the front chassis.
  4. Sony ICF-C1iPMK2 Control Buttons Replacement: paso 4, imagen 1 de 2 Sony ICF-C1iPMK2 Control Buttons Replacement: paso 4, imagen 2 de 2
    • Remove the 1 cm Phillips #00 screws on the board.
    • Pull the plastic buttons off of the housing.
  5. Sony ICF-C1iPMK2 Control Buttons Replacement: paso 5, imagen 1 de 2 Sony ICF-C1iPMK2 Control Buttons Replacement: paso 5, imagen 2 de 2
    • This next step requires soldering. Be careful when handling a soldering iron as you can easily burn yourself on it and the hot liquid solder. Make sure to desolder and solder in a well ventilated area to not inhale heavy metals, possibly lead. (If you buy iFixit solder there will not be any lead in the solder, but it is still best practice)
    • Place the soldering iron onto the solder joint of the broken button.
    • Once melted, remove the button, being careful to not touch the melted metal.
    • Replace the button and touch the soldering iron to the solder wire over the button contacts. Refer to the prerequisite guide if you need more help.
Conclusión
Give the new solder 30 to 45 seconds to cool before reassembling.
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 95
