Saltar al contenido principal
Sony ICF-C1T Tuner Dial Replacement
Qué necesitas
  1. Sony ICF-C1T Tuner Dial Replacement, Tuner Dial: paso 1, imagen 1 de 1
    • Using the Phillips #00 screwdriver, remove four 14mm screws from the underside of the device.
    • Make sure that the clock is unplugged and the battery is removed before tampering with the device to avoid electrical shock.
  2. Sony ICF-C1T Tuner Dial Replacement: paso 2, imagen 1 de 1
    • Use the opening tool to pry apart the edges of the top and side portions of the device.
  3. Sony ICF-C1T Tuner Dial Replacement: paso 3, imagen 1 de 2 Sony ICF-C1T Tuner Dial Replacement: paso 3, imagen 2 de 2
    • Separate the device by gently pulling up on the top portion.
    • Use caution when pulling the device apart as the clock display is located close to the front face plate and is connected by multiple wires.
  4. Sony ICF-C1T Tuner Dial Replacement: paso 4, imagen 1 de 2 Sony ICF-C1T Tuner Dial Replacement: paso 4, imagen 2 de 2
    • To remove the motherboard, gently pull apart the sides of the device.
    • Do not pull hard on the motherboard, because it is still connected by multiple wires inside the device.
    • Be careful of sharp pieces on the motherboard.
    • Having help for this step might make things quicker and easier.
  5. Sony ICF-C1T Tuner Dial Replacement: paso 5, imagen 1 de 3 Sony ICF-C1T Tuner Dial Replacement: paso 5, imagen 2 de 3 Sony ICF-C1T Tuner Dial Replacement: paso 5, imagen 3 de 3
    • Remove the tuner dial by pulling it off of the motherboard. This can take a little force to remove.
Conclusión
Un comentario
Thanks, this was not fun but the guide helped.
Campbell Kerr - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 24
Todo El Tiempo: 1,592
