Saltar al contenido principal
Sony ICF-C1T Screen Replacement
Qué necesitas
  1. Sony ICF-C1T Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Make sure the clock is unplugged from the wall and the replacement battery has been taken out of the clock to prevent harm to you and to the clock.
    • Use a Phillips 00 head screwdriver to remove the four 14 mm screws from the bottom of the clock.
  2. Sony ICF-C1T Screen Replacement: paso 2, imagen 1 de 1
    • Insert the plastic opening tool to pry apart the top and sides of the device gently.
  3. Sony ICF-C1T Screen Replacement: paso 3, imagen 1 de 2 Sony ICF-C1T Screen Replacement: paso 3, imagen 2 de 2
    • Carefully pull the top of clock off as the clock display is located directly behind the face plate and is still connected by multiple wires.
    • Pull the top of the device away from the rest of the clock to expose the inside.
  4. Sony ICF-C1T Screen Replacement: paso 4, imagen 1 de 2 Sony ICF-C1T Screen Replacement: paso 4, imagen 2 de 2
    • Do not use too much pressure on the plastic to not break it.
    • Add pressure to the inside of the screen so that a small area is loosened enough to be able to use an opening tool.
    • Use the plastic opening tool to separate the screen from the device.
  5. Sony ICF-C1T Screen Replacement: paso 5, imagen 1 de 2 Sony ICF-C1T Screen Replacement: paso 5, imagen 2 de 2
    • Apply a tinted spray to dim the brightness once the tinted sheet is out of the way.
    • Another way to solve the brightness problem is to apply a tinted color sheet protector.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 14
Ultimos 30 días: 42
Todo El Tiempo: 4,524
