Saltar al contenido principal
Sony Handycam HDR-CX675 Camera Shell Replacement
Qué necesitas
  1. Sony Handycam HDR-CX675 Camera Shell Replacement, Camera Shell: paso 1, imagen 1 de 1
    • The battery should be removed and oriented upwards.
  2. Sony Handycam HDR-CX675 Camera Shell Replacement: paso 2, imagen 1 de 1
    • Remove the side 4.5 mm JIS #00 screw using JIS Screwdriver
    • Remove the 5.5 mm JIS #00 screw.
  3. Sony Handycam HDR-CX675 Camera Shell Replacement: paso 3, imagen 1 de 2 Sony Handycam HDR-CX675 Camera Shell Replacement: paso 3, imagen 2 de 2
    • Gently pry the plastic case surrounding the start/stop button free by using the blue plastic opening tools.
    • Remove the casing using your thumb and index finger.
  4. Sony Handycam HDR-CX675 Camera Shell Replacement: paso 4, imagen 1 de 1
    • Turn the camera around and flip open the LCD screen to expose the side panel.
    • Remove the 5.5mm #00 screw using the J00 head screwdriver.
  5. Sony Handycam HDR-CX675 Camera Shell Replacement: paso 5, imagen 1 de 1
    • Turn the camera to the handgrip side and unscrew two of the 5.5mm JIS #00 head screws using the JIS #00 head screwdriver.
  6. Sony Handycam HDR-CX675 Camera Shell Replacement: paso 6, imagen 1 de 1
    • Remove the two 5.5mm JIS #00 screws with the bottom of the camera facing up.
  7. Sony Handycam HDR-CX675 Camera Shell Replacement: paso 7, imagen 1 de 1
    • Turn the camera around in a way that the bottom of the camera is facing you.
    • Use the blue opening tool to gently remove the camera shell off of the camera.
Conclusión
5 personas más completaron esta guía.
Mohamed Nazer
Miembro Desde 02/15/17
403 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 8-2, Eyestone Spring 2017 Miembro de USF Tampa, Team 8-2, Eyestone Spring 2017
USFT-EYESTONE-S17S8G2
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 29
Todo El Tiempo: 751
