Introducción
In this guide you will work through the process of removing the lens from the camera. This involves removing many moving parts of the camera, as well as some wiring and large amount of casing. This will, however, allow you to clean the lens more directly.
Qué necesitas
Locate the slider labeled "BATT" and pull it back from the battery with your thumb.
Use the Phillips #00 head to remove the following 5.5mm screws on the left-hand side.
Use the Phillips #00 head to remove the following 5.5mm screws on the right-hand side near the lens.
